How much and what cable do you recommend?
The SE is $1800
I have not found a cable worthy of my new babyâŚenjoying looking ![]()
Just a shame about the cable for a 1800$ set.
Agreed on the cable - isnât 64Audio known for particularly crappy cables for their sets too?
Yep. The U12t has a crappy cable.
Yeah thatâs what Iâve heard. Itâd be amazing if these larger companies can figure out how to make cables like or even recruit people like XINHS to make their cables. I have a $20 (Literally) cable from XINHS and its fantastic. So I donât think cost is an issue.
The Truthears Zero uses a cable just like what 64 Audio used for years.
For a $50 set itâs great.
This set having a ghetto cable in 2022 is kinda infuriating.
I paid a lot. it sounds amazing.
Buy a better cable in bulk of Alibaba and fucking try harder man.
I hate when companies do A-Y then⌠get to Z and say âMeh, fuck itâŚwe did enoughâ
It is usually tuning
I get it, they donât know what the fuck they are doing.
This is a cable man.
I could DM 1 person in this hobby, pick the cable, say i want on my set.
It would be done.
Get it done.
Right. I canât imagine getting a cable right is anything hard to do in this hobby at this point in time. With so many people doing an amazing job on cables, youâd be hard pressed to find a shortage of talented folk to work with.
Yeah, to add to the pile-on: having to buy an upgrade cable for your $20,$50,$100 set? Maybe you grumble but you get it
Having to buy an upgrade your cable on an $1800 custom-order set?
YEAH, NOPE!
Yeah 64 is usually overpriced for sound quality but their build quality is solid.
Some of my chifi stuff usually have qa issues. Some issues minor some big. It doesnât matter for cheap stuff but they start charging American prices for crappy build quality and thatâs a problem.
Of course Japan iems are usually built like a tank.
But yeah, for that much money i shouldnât have to buy a cable too.
Dam u got me hype on that one. Never heard u consider a iem to be better than Elysian.
A Japan exception, maybe there are more, is driver matching in Final Audio IEMs â many documented cases of terrible matching. Iâve never noticed an imbalance in either E4000 Iâve owned, but Iâve never graphed them.
It sounds fantastic.
I had to return a pair of e5000s because the bass on the right IEM was noticeably higher compared to the left. Itâs the most blatant example of driver mismatching I have ever personally experienced. The replacement pair I received was fine though and I have owned two other Final IEMs with no problems.
You are like Rain man or something.
Thatâs the exact cable you thought it was
Me
âŚ
(10characters
If anyone wonders this is most likely Openheart 8 core cable (15$). I used to have one for HE-400i and like it very much ![]()
79,50 zĹ 50%OFF | OPENHEART 8 Core Original MMCX Cable for Earphones 3.5mm Upgrade Replacement Silver Cables 1.4m Lengthen Goodlooking Personality
https://a.aliexpress.com/_mLyGLnS
