Thatā¦is such a classic track!!
Thank you.
I was not expecting that on multiple fronts. The Hype 10 is a big boy price range set, which are usually in the auction for animal shelters ( which is so cool ), and an IEM I was curious about. I find ThieAudio makes great gear, just most of it is out of my price range.
@hawaiibadboy I emailed, the main channel address, since I didnāt see one on the unboxing channel. If that wasnāt the right thing to do, just let me know. Thanks again, and happy holidays.
. In todays video you where both hard and soft manā:smile:. Enjoy the holidays with your family Chris!
And congrats to you Johnšš»
I thought i recognized the avatar. it will be sent this coming weekend. Congrats. I hope the fam is doing well and has a great holiday season ![]()
Congrats man looking forward to your thoughts on that set ![]()
I have a bunch of those Final E tips. At one point I used them on pretty much everything. Will give those a try later today.
Interesting. When you say chopped foams, do you mean something like the Comply foams with the excess foam snipped off the end?
Great review, man. Thanks. For something thatās under a $100 I am also considering to purchase the āTangzu YU Xuan Jiā. For some reason cheap IEMās keep getting better lol. I might have to dig in a little bit and compare the Xuan Ji and Sivga Que !
I generally chop the front part, gives me great seal. They donāt really look very good, but they do wonders
Interestingā¦these fit in the cavity well? I always assumed the rounder part in the front made these go in smoother and stay there.
I donāt want to answer for someone else, what introvertguy has to say may be different, but generally with foams you can pinch them into a sharp shape even if they start as a cylinder.
Ahh rightt makes senseā¦every time i use my se535s for a long time they come out of the ear looking like arrowheads xD
@hawaiibadboy more crazy Rock history I didnāt know aboutā¦
Same, running Springtips on Punch and itās working really nicely. Other stuff like Divinus seem to bring mids forward a little more but I really like what the Springtips are doing.
The Sex Pistols stole all their gear out the back of a venue⦠but I donāt think they were at large at the time ![]()
Forgot to add them to the shame list. I dont really remember exactly what happened though, mind explaining it? @VIVIDICI_111
Hi! Anyone here using the silver grand maestro cable? Does anyone know where can i buy a 4.4mm connector? They sent a 2x 3.5mm, it looks like a termx connector as well but im not sure so its better to ask here first, thanks!
Looks to be the same OE plug style that Symphonium and others use: OE Plug Interchangeable Heads
Is it one of those 4 pin socket? Like this
Itās very similar, but the alignment mechanism is different; OE plugs have a little plastic ādotā that sockets into place to ensure the pins are correct for the connector to the cable (Iām currently trying to unscrew mine to show).
Edit: Pics of the connectors and side of the barrel. A collar screws onto the connector to secure it into place.
@BassEars Obviously you can confirm with Elysian or whomever made your cable, but based on the design I am 99.5% sure itās just a āstandardā OE Plug termination which, as you can see, is indeed available in 4.4mm.
Edit: @toranku @SoundJedi can either of you confirm if Elysian uses OE Plugs for their interchangable termination?
