Hi!
I need some help finding balanced cables to connect a SMSL SU-8S Dac to an IFI Zen Can. I think what I require are dual female XLR to 4.4mm pentacon.
In my browsing, I’ve only found a dual male XLR to 4.4.
Any direction would be much appreciated!
Welcome to hifiguides. If you tell your location it is easier to find something that is available for you.
If you don’t mind the look you could also just use any male XLR cable and some gender changers.
Thanks for the info! Much appreciated!
