Bamboo Audio rack
Have enough Shiit and being that I live in Spain where it is already plenty warm I figure putting some ventilation space twix these three (four if you count the computer) is not a bad idea.
Materials thus far:
Bamboo Cutting Boards - sourced from local MaxiChina ~ 3 euros each
100mm long, interior threaded (M10) black AL lamp necks - Aliexpress x 10
  • have just reordered 80mm as well to try
M10 lamp neck connectors
M10 washers
Base feet with M10 → the threads on these are way larger than the lamp neck threads so will have to either rethread or force.
…build upcoming
So I quit complicating my life…threaded rod and nuts with a top cap…the bamboo are sushi plates with a 1cm lip which just hides the nuts which support the boards..
Oh Damn I like this!! Might be a home depot trip coming up LOL!!! Thanks for the pic and nice job!
worth it…just got everything stacked…
Look very Good :+1::grin:
Nice… gives me ideas for sure… BF2 on the bottom, A3 middle and LP next then finally desk lamp top… Yes going to look into doing this… Thanks.
That is beautiful! Nice work. :+1:
That looks really good :slight_smile: Been thinking about a DIY like this myself. Bamboo is a great idea.
Thats beautiful for sure. you can spray paint it or wrap it too.
Nice work!
The bottom shelf I used 14mm diameter gray tubing to cover the 10mm rod…I think if I got some black , or painted what I have black it would look even better. I also will put some felt on the bottom as currently the base is 4x M10 nuts
So…if I get the Mjolnir…it’s 40cm x 20cm…this rack is currently 32 x 23 outside edge with space for components that are 29 x 23…further more 40 would sit off the edge of the drawers this sits on…but fuck I want to try the Mjolnir.
Got a balanced cable for the Audezes and the Campfires arrived
Also one of the black knobs I ordered arrived and it’s perfect for Oreo!
Well…gonna have to rethink this now/ Rebuild to fit the Mjolnir and Gungnir…Found the bamboo board on Amazon…little more expensive…may have to check Maxi China again
And now have a designated piece of furniture…so that escalated quickly…
