Best $50/€ IEMs
I need to buy some IEMs costing around €50, though I don’t mind spending a bit more if it’s worth it (I’ve listed two options around the €75 mark). I’ll be using them with a Steinberg UR22 interface connected to a PC. I plan to use them for a lot of gaming, but also for music, YouTube, and playing guitar and bass.
I’ve read about many options in this price range, and the ones people recommend are listed below. If you know of any others that are better, please let me know, as I know there are many choices in this price bracket.
• 7Hz Salnotes Zero 2 €25
• KZ PRX €30
• Moondrop Lan €52
• JUZEAR Nimbus €56
• Moondrop Lan II €58
• Zhulinniao Qingluan z4 57€
• SIVGA QUE €59
• Truthear Zero Red €60
• Truthear Zero Blue 2 €60
• Artpical Game One €73
• Artti T10 €78
Welcome to the forum!! :blush:
You have listed many good ones. I have not heard most of them, but Chu III are really nice! 7Hz Zero 2 is also great. The Juzear set gets a lot of attention lately.
More people are probably going to chime in as they see your question.
I would bet on:
Artpical Game One, Artti T10,JUZEAR Nimbus.:slightly_smiling_face:
Artti T10, Melody Wings Jupiter
I have the Moondrop Chu 3 and they need EQ for gaming. With the Autoeq Harman no bass or diffuse profile they’re excellent, stock the bass bleeds into the mids. The Truthear Gate are best out of the box, and extremely low distortion measured at ASR.
The Truthear Zero blue for lush vocals, red for lower distortion and gaming. Artti T10 treble can be fatiguing but very nice cable.
This might be a stupid question, but will my Steinberg UR22 have enough power for planar-driver IEMs like the Artti T10?
EDIT: The data is in the manual - Maximum Output Level 6 mW+6 mW, 40 Ω
Do not bother with the Nimbus, Juzear has not fixed their crappy QC since the first time I had the Defiant. So no, remove that one from the list, not worth the headache you’ll eventually encounter it.
Why? I have 1 Defiant that broke, and 2 sets of Nimbuses that broke on me, due to the right drivers dying for no damn reason at all.
Depends purely on your listening volume.
80 db average volume + 20db headroom (peaks) is doable for sure.
With 6mW@40ohm, it would be 12mW@20ohm so a bit higher for 16.5ohm in the T10. But lets assume 12mW for ease of math,:
87 db average volume + 20db headroom (peaks) should be doable as well. But that would be at max volume, at which point you may have distortion from the amp or other issues, as that really is terribly low power and i assume a garbage amp
For reference a simple dongle around 10 usd (like from Jcally) usually has around 32mW at 32ohm.
Thanks for the reply. Honestly, it all sounds like Mandarin Chinese to me. English isn’t my native language either. But I think I’ve gathered that for an Artti T10, I should buy a dongle. For other IEMs that don’t have planar drivers, I wouldn’t have any issues, right?
yes you should just get a dongle. Jcally JA3 is tiny. Fiio Jiezi has built in PEQ. Those are my recs.
Is there any way I can use a DAC and my Steinberg interface at the same time? Because if I play bass or guitar through the computer, I have to keep my headphones plugged into the interface; I can’t plug them into the PC because the audio driver has to be the interface’s driver, for both input and output.
I’d look at sensitivity as well, not just whether it’s planar or not.Since you’re using them for gaming, music and guitar/bass, I’d probably prioritize imaging, comfort and easy drivability. If one IEM needs extra gear just to work well with your UR22, that would personally make it a little less attractive as an all-rounder.
Yes, I think so too. I’d rather buy something I can use with the Steinberg UR22. For example, would the Kefine Klean work? Sensitivity: 108 dB +/- 3 dB
Impedance: 26 ohms
Basically the steinberg is only doing the INPUT and a separate dac&amp would do OUTPUT? That should work. You can try it with a dongle if you dont wanna spend much, it looks ghetto though. Like the Fiio Jiezi.
Here is the site i use.
https://headphones.com/pages/headphones-power-calculator
That isn’t possible, because recording interfaces use their own low-latency audio drivers, and the only audio outputs that can be used are the ones on the interface itself
According to that website, the Kefine Klean require 1.58 mW of power. That means my interface, with its 6 mW, can definitely drive them, right?
You can on Linux, use one deviced for input and another for output and lets you pick what to use. I dunno about winslop.
That is at 90db +20 db headroom (110db volume). Depends on your listening volume as i said above but yes i do doubt you use anything higher than this already high assumption.
You can do it on Windows too, but not with the interface’s driver, rather with the Realtek driver (I assume it’s the same on Linux). With the Realtek driver, the latency makes it impossible to play an instrument like a bass or guitar; using the Steinberg driver is mandatory.
I don’t use headphones at high volume, quite the opposite.
You need a db meter to check this (or use one of the db meter apps in your phone) and you can use whatever speakers you have access to as a reference to your listening volumes. (measuring iem volume you would need more tools for that.)
