Best AIO Bluetooth dac? Topping EX5, DX7 Pro etc?
I have a JDS Atom and Topping BC3, and after buying HE1000SE and Utopia, I should probably upgrade… Plus, the BC3 touch controls are horrific to use.
I found some great value options - Topping DX7 Pro (used) for £400. Or Topping EX5 (new) for £350. Both look very similar, and I don’t know which is better. It’s the non-plus DX7 Pro, to clarify. And I don’t use IEMs, so the impedance is fine.
Then there’s the DX3 Pro+, even cheaper.
Are there even better options around the price, besides those? I heard great reviews of the DX7 Pro with Hifiman HE1000SE, which I’m using. Not sure about the EX5, but it could be even better? And it seems the DX3 Pro+ doesn’t have much of a downgrade, except balanced output. I could pair it with a £200 amp and be done too.
And will they sound audibly better than my JDS Atom? Thanks!
For a few quid more then this might be worth a look :+1:
Hmm, that’s a bit out of my price range, but I’ll keep it in mind!
How about the new hifiman DAC/amp? I’ve read it’s pretty great for the 1000s and I’m sure the utopia would sound good with it.
I’ve heard that’s good, will keep it on my list. But preferably I’d want Bluetooth (since I use BT when listening in bed)
Get a sender/reciever like fiio has or taotronics
