The initial attack won’t be in impacted. Resonance and decay will be affected slightly and will add to additional kind of like timbre like response. Only if you have sensitive hearing or if you have experience with wood long enough will you pick out the differences. For what its worth, I have 100% confidence the stock offerings from ZMF I’m sure are next to the best choices.
Hey im also thinking about the Awas, AWKT or Eikon. I was checking out the AWKT and i maybe order one to try it. But i was wondering If anyone tried those before. How does AWKT live Up to the Price increase vs AWAS.
You get an increase in technicalities, better control and more resolution, but the awas is a smoother warmer more forgiving where the awkt is going to operate more on garbage in garbage out
Okay and the Fostex TH900 mk2? Probably the heaviest Bass.
I can test the ATH. If only i could Test them directly to the Eikons
I really like the th900 mk2 for pretty crazy subbass fun with lots of treble detail, intimate and aggressive with lots of depth, very fun
