Hello, I’ve just purchased a flat, and have no audio gear apart from my v-moda m100 and fiio e18.
I’ve seen some Borea’s br03 reviews and I can get them for 399€, the thing is, I cannot choose what DAC/amp should I get for them.
I don’t know which of them suits best the Br03, can someone help me?
I wouldn’t want to spend more than 600 on the dac/amp section, because I also have to buy some foot stands for the boreas, and all I’ve found seem quite expensive for me.
Any notable difference between the two? i’ve seen the IOTAVX SA3 doesn’t have Bluetooth by default, that being an add-on(€),+ it doesn’t support LDAC, is kinda the same scenario as the pma600 that don’t have aptxhd.
So, Bluetooth apart, what should make me lean more to one, or the other? being the IOTAVX 130€ more expensive than the pma600ne.
Hmm, it will be faster and more punchy, but also harsher and a tad bit more lean sounding. Honestly both are great lol, I think it comes down to preference
Might want something to bring up the highs for edm with the bro3’s… they’re pretty mellow up top… yamaha might be worth looking at… I’m sure theres other brands that could do that job too though
i’m currently in the same situation. I’ve ordered me some BR03’s to replace my broken vintage Optonicas. I will see how they perform on my old Harman/Kardon set. And, regardless of the outcome, i’d probably want to get some decent amping. I’m actually leaning towards seperate components like a Behringer A800 or a Crown amp + a good preamp. But paying all of that at once might be not wise and i’m a beginner in seperate setups. If i get power amp like this - can i use my Chord Mojo as a temporary preamp replacement, would that work well?! If not - do you guys have recommendations regarding preamp+power amp (class D?) combos that might work well with the BROs?
i’m just adding, that i ended up with the IOTAVX SA3 + BR03-combo back then. And i highly approve it And it made an quite obvious difference to the old HK AVR. And i can highly recommend as a stellar “budget” solution.
