Till now i have shortlisted topping dx7 pro, monolith thx, asgard 3 + modius
Headphones which i will use are argon mk3, focal clears and sundara
Other recommendations are also appreciated
Any reason you’re limiting yourself to a dac/amp combo unit rather than separates?
No I am fine with seperates as well
JDS Labs Element II should be on the list.
It was but I don’t think it has enough power for argon mk3
Should be enough power
Lake People G103S is not bad as Amp.
Topping E30/L30 combo has great bang for the buck.
With $500 budget, you could go for the modius/magnius or asgard 3/modius, topping e30/l30, if you can find it used the lake people g111 or rupert neve rnhp amp + maybe smsl su8 or modius.
Decided on asgard 3/ modius
The modius can‘t play Dsd.
There where be a option when play it with Audirvana later with a Topping E30 who is cheaper.
