Best headphones amp to run 250ohm at a reasonable price?
Which headphones amps do you recommend to run headphones that are 250 ohm ?
I heard fijo? any suggestions guys?
Thank you.
Give the IFI Zen DAC/AMP a try if you can afford it for I have heard good things about it. Also, for the portable amp version I am using the Topping NX3s for my DT 880 Pro 250Ohm version and it is working for me so far, pretty good for the price.
Topping L30 is coming if you can wait.
If not, JDS Labs Atom or iFi Zen Dac.
How about the Schiit Asgard 3? Where are you located?
I am in Italy brother, i just checked it out, amazing. How can i get it delivered here and since i have the komplete audio 6, does it connect there ?
I don’t think you can get Schiit gear in Europe. That is why I asked. Schiit, Drop and even Monoprice are hard, if not impossible to get in Europe.
Maybe look at Lake People?
maybe thats too expensive… maybe something more affordable to start with?
I have no idea what’s available in Europe. All I can recommend is trying your Amazon. Maybe something Topping or SMSL?
I think better to say what are your headphones first
  • JDS Labs can ship to italy: Atom Dac+Atom Amp+shipping to italy = 210 euros (make sure to choose euro plug) CLICK HERE
  • Fiio K5 Pro in amazon italy for 179 euros CLICK HERE
  • Topping A30+D30= 180 euros from https://shenzhenaudio.com/ (they ship to italy)
  • ifi Zen Dac from ebay new ships from UK to you= 160 euros CLICK HERE
Those are cheaper than asgard3… but which is better will depend on your headphones and the more experienced members will guide you better.
Schiit has an EU web site where you can order from, so there is no problem getting their products. There has been a baglog due to Covid 19, but you can order here:
https://www.schiit-europe.com/
I have ordered from both Drop and Monoprice also to Europe, so you have those options as well.
Yup.
JDS Labs Atom: 1W per channel for 100$.
Schiit Heresy: 2W per channel for 100$.
Fiio K5 Pro DAC and Amp: 1.5W for 150$.
Schiit Asgard 3: 3.5W Class AB for 200$.
If you need a passive speaker amp too, there’s the Emotiva BasX A100 for 230$ (speaker amp and overkill headphone amp). Open it, change a jumper and you get [email protected]. Yes, into headphones. Webpage says “USE WITH CAUTION”.
Note that Emotiva BasX A100 has relatively high noise.
Everything is out of stock, and before Covid 80 percent as well, around Christmas I tried to get amps and Dacs and no luck
I hope not it ends like Drop, who cancelled their EU site + storage. I don’t know if Schiit has a storage in EU, but you are right about them having few products available.
But there should be a decent group of customers here, to keep the EU site open. We just need products…
