Best Headphones in 2025 | Expert Recommendations
I have researched the best headphones because I’m looking for a pair with premium sound, strong ANC, and long-lasting comfort. After comparing reviews on Head-Fi, RTINGS, and The Headphone Show, I’ve narrowed it down to two top-rated models:
Beats Studio Pro - Wireless Bluetooth Noise Cancelling Headphones
https://www.amazon.com/Beats-Studio-Pro-Personalized-Compatibility/dp/B0C8PR4W22
Apple AirPods Max Wireless Over-Ear Headphones
https://www.amazon.com/Apple-Headphones-Cancellation-Transparency-Personalized/dp/B0DGJC52FP
I’ll mainly use them for music (hip-hop, acoustic, EDM), work, and travel — so comfort and sound quality are both important for me.
If anyone has experience with either of these, I’d really appreciate your insights or personal recommendations. Which one do you prefer and why?
Thanks in advance!
IMO I’d go for the 3rd door :smiley:
i would suggest looking at the Focal Bathys or even the audeze Maxwell (it’s a little on the heavy side).
at the end of the day both apple and beats are apple products (apple owns the beats brand) …
i highly dislike the design and overall usablity of apple products particularly the Air pods max (the materials used and the stupid case). that being said Apple’s ANC is top notch (Sony and apple lead the pack in that regard), and thier tuning is unoffensive (its not good, just not bad).
Beats used to be all bass, but they have improved since then (i havent heard the Studio pro, but it’s been a trend for the last while) , to me Beats have worse ANC and feel cheaper.
@Naturallymorbid is correct: You can do a lot better than Beats or AirPods Max.
His suggestion of the Focal Bathys is very solid. A much better can than the Beats or Apple models.
Focal bathys or the Bose Quiet Comfort (ultra), or perhaps apple will get off their arse and show off a new AirPods Max headphone at their September event
pretty sure most people thought airpods max were “ok” at launch besides being overpriced.
heard beats stuff has gotten better than it used to be but still behind the curve.
maxwell depends on your head size, for me the adjustments were either too loose or my ears pressed against the top of the pad.
have heard pretty good things about a couple of the focal wireless headphones.
noble audio has a pretty new one that seems to be well received so far.
