I was thinking about buying a new portable speaker, my budget is set on 70 dollars.
I’ve been thinking about the Tribit StormBox, it seems to have everything I need, powerful, long battery life, waterproof etc.
If you have some recommendations, please leave them below.
Thanks in advance.
I’ve got these hanging in my shower. They’re quite good and around 50 bucks. Also the Flip are quite good as well.
This is what I use at work, in a loud refrigerated meat cutting room. You can buy 2 and pair them together. Has surprisingly good bass, has 360 sound, which sounds great hung up in a corner of a room. Waterproof,
https://www.amazon.com/dp/B07SGXBR2H/ref=cm_sw_r_cp_apa_i_dQbqFb30NSC3R
