Best portable DAC with a Lightning adapter for under £25?
So as I’ve now bought the CRA and Bl-03 IEMs, Spinfit eartips, I’ve read a DAC is needed for optimum SQ/bass
I’m looking for a portable DAC with a lightning connector to use with my iPhone 12
Any recommendations …
Thanks
If it’s to power those… and you have an iPhone… then the standard iPhone lightning to 3.5mm cable.
It has a great DAC in it, and plenty of power for the sets you’re talking about. It’s the performance to price king for iPhones.
Although to be fair neither model needs the power anyway, but they will both need a jack (thanks Jony Ive)
Agreed. The Lightning to 3.5mm Apple Dongle is great and cheap. You don’t need more for most IEMs.
Oh good, I already use this dongle
Thanks
Is Bluetooth also on the table? Cause the FIIO μBTR is around 30 (less on Aliexpress)
