Best portable power station, Expert recommendations to choose
I researched the best portable power station to support my needs for camping trips, backup during power outages and maybe even some light rv use. After reading expert reviews from trusted sources like the new york times,consumer reports and techradar,two models consistently come up as top recommendations.
The Jackery explorer 1000 v2 comes with a 1070Wh LiFePO4 battery and offers a 1500w ac output along with a 100w USB-C port. One thing that really stands out is its ability to fully charge in just one hour. It is also a solar compatible solar panel and many users say it is a great choice for camping, off grid living and emergency power.
On the other hand, the Ef Ecoflow delta 2 max is slightly larger with a 2048Wh LFP battery and a powerful 2400W ac output. Like the Jackery, it also charges fully in an hour and is solar ready. It is often recommended for home backup needs and for people who want reliable power during outages or when traveling.
However,I am having trouble deciding which one would suit me better. I plan to use the power station mostly for charging phones, laptops and small appliances while camping or during blackouts. Quick charging is definitely a plus for me but I also care about long battery life, durability and how easy it is to carry around.
So, between the Jackery Explorer 1000 v2 and the EcoFlow DELTA 2 Max, which one would you recommend? Has anyone here had personal experience with either of these? Any experience or suggestions would be appreciated.
Thanks in advance
Between the two, the ECOFLOW DELTA 2 Max is a better choice for sure.
But, I’m a bit skeptical of sites like TechRadar sometimes, especially when it comes to stuff with batteries and power. They seem to feature a lot of products I’ve barely heard of, like https://www.deeno.com/product/deeno-gt-s1500, ALLPOWERS R4000 Portable Power Station 4000W 3600Wh Backup Power Supply, FOSSiBOT F2400 Portable Power Station | 2,400W 2,048Wh. For someone who doesn’t live and breathe this tech, it’d be super easy to get pointed in the wrong direction.
My advice? Before you pull the trigger, maybe check out some YouTube reviews. You can usually find some really in-depth videos from folks who really know their stuff.
@Rocky313
Further refine your use case(s). Both are LFP meaning something else in the device will let out the magic smoke long before the cells.
Twice the Wh really means twice the weight. One is 24lbs the other 50lbs. This should go a long way to deciding which is ā€˜best’.
1500W AC is effectively the work a standard 15A outlet at home (not quite but really how often do you pull max 1800W from an outlet at home)
Unless you plan on running multiple AC loads at the same time I would argue 2400W is overkill for the use case you outline.
My very most useful ā€˜power stations’ are my smallest ~300Wh like the old Jackery 300. 99% of the time I only want to charge another battery powered device or run a small AC appliance for a modest amount of time.
Neither of these will support your air conditioner during an outage, nor your electric stove or water heater so is the double the capacity and weight and more than double the cost really ideal for your needs. I don’t think so.
There is no one size fits all but I’ve found over the years I’ve been best served by having two smaller units to take where I need and either have other solar/battery systems to charge them and/or alternator charging when driving. I simply wouldn’t take the 50lbs device unless it was my sole power source for a vehicle but I could argue that it’s likely not enough depending on loads and duration :wink:
honestly, you can’t go wrong with either. for your use (phones, laptops, a couple of small appliances while camping / during blackouts), i’d lean toward the jackery 1000 v2 because it’s lighter, easy to toss in the car, and the quick-charge is legit. the delta 2 max is a beast—double the capacity and a much bigger inverter—but it’s more of a ā€œleave it in one spot for home backupā€ kind of unit.
that said, i ended up going with a middle-ground option i’ve been happy with: UDPOWER S1200. it’s an LFP pack around 1.2 kWh with a 1200 W inverter (1800 W surge), fast wall charging, and a super-snappy UPS. weight is in the mid-20-lb range, so it’s still carryable for weekend trips. if you want a bit more capacity and more ports than the jackery—without jumping to the ~50-lb class—the S1200 hits a nice sweet spot. (product page: UDPOWER Portable Power Station 1000W)
quick ballparks for what you mentioned (very rough, assuming ~85% usable and steady loads):
  • 60 W laptop: ~15–17 h on a ~1.1–1.2 kWh unit (jackery 1000 v2 / S1200), ~29 h on a ~2 kWh unit (delta 2 max).
  • mini-fridge averaging ~50 W: ~20 h on ~1.2 kWh, ~35 h on ~2 kWh.
  • phones are trivial—dozens of recharges on anything 1 kWh+.
my take:
  • want the lightest setup that still covers camping + short outages? jackery 1000 v2.
  • want longer runtimes or plan to run heavier stuff? delta 2 max.
  • want a practical middle ground with lots of ports and quick UPS? UDPOWER S1200.
After using a few different power stations over the past year, I figured I’d share an update in case it helps others decide. I previously used some of the smaller and mid-range units mentioned earlier in this thread, and while they were fine for light use, they didn’t hold up as well for longer outages or heavier loads in my case.
I’ve since switched to two models that have worked much better for my needs after reading a lot of reviews, checking long-term customer feedback on Amazon, and also getting hands-on advice from a friend who owns and uses both regularly.
The first is the Jackery HomePower 3000. This thing is clearly designed with serious home backup in mind. It has a large 3072Wh LiFePO4 battery, a strong 3600W output (with up to 7200W surge), and comes bundled with 2Ɨ200W solar panels, which makes it great for extended outages or RV use. It’s not something you casually move around every day, but for reliability, battery longevity, and solar performance, it’s been rock solid so far.
https://www.amazon.com/Jackery-HomePower-Generator-Essential-Emergencies/dp/B0FFSDCNR4/?th=1
The second one I’m currently using is the Anker SOLIX C2000 Gen 2. This one feels like a really nice balance between power and portability. With a 2048Wh LFP battery and a 2400W inverter (4000W peak), it handles laptops, kitchen appliances, power tools, and even short fridge runtimes without breaking a sweat. The fast charging is impressive too — hitting a full charge in under an hour from the wall has been very convenient during outages. Anker’s build quality and power management have honestly exceeded my expectations.
https://www.amazon.com/Anker-Portable-Station-Generator-Optional/dp/B0FVFGL38H/?th=1
Based on my experience, the smaller units are great for camping and light use, but if you want something dependable for home backup + camping + emergencies, stepping up to these higher-capacity models made a noticeable difference for me. I didn’t pick them blindly — real-world feedback from other users and friends played a big role, and so far they’ve proven to be reliable.
Hope this helps anyone still on the fence. It always comes down to how much power you actually need and how long you want to run it.
