IMO I think the atom still edges out the heresy for really small things like timbre and presentation, but realistically I think the heresy is the better buy for most because of the better build and the higher headroom, they sound damn close
They all use the same inherent design, they will sound the same because of it. The heresy has more power, thatâs it. So because more power, same sound, Heresy > Atom. If you donât need the power, then it really doesnât matter.
Sound quality is pretty close to a wash. Heresy has more than twice the power of the Atom. If you have really power-hungry headphones (like Fostex T50rp or mods based on it) the Heresy is the choice. The Atom has 2 inputs. You could connect your pc and a turntable (if you have a phono preamp) for example. It really depends which feature set you need.
