Best sound stage and direction for around $200-350
Hi, I am just getting into the world of headphones, I would like a pair that has…(open or closed)
really good sound stage
really good direction
good dynamic range
I can get an amp if needed everything else can be decent I think, if it is not possible to get all of that for the price or something better is only $x more please tell me. I have some superlux hd668b’s but they are old and I want something better. it would be nice to be able to use them with my phone without a amp but that is at the bottom of the list.
Music.
Gale Song
inception soundtrack
Yver Nontand - Sous Le Chiel De Paris
mewithoutyou
The Decemberists
Iliketrains
Chris Cornell - Like a Stone
any help would be nice, thank you
Would this budget include the dac/amp or just the headphones?
just headphones
I’m kind of thinking a dt880 600 ohm or hifiman sundara, although they wouldn’t work well on a phone tbh. You might be able to consider a portable amp though (although it’s not the most ideal). I think if you really wanted to get something that checks all your boxes something like a used focal elex would be something to consider or perhaps a dt1990
yeh…you’d definitely need a portable amp for the DT880’s. the Sundara’s are open back, so there will be audio leakage to those around you and if the environment is noisy, will bleed into what you’re hearing as well. in your room or whatever, they’ll be awesome!
AKG 701 or a used set of the AKG 702’s…
