Best Subwoofer Around $500 USD?
I went with a pair of OSD TREVOCE12’s. It’s a 12" 4ohm sub with 2 12" passive carbon fiber radiators and no ports. It’s rated at 800watts max (probably 400 watts RMS) and has a DSP bluetooth app to help match them to the speakers. It’s rated to go down to 20hz and seems to accomplish it. I called them and was able to get 2 shipped for $580. They aren’t SPL type subwoofers. More like a 12" sealed system but slightly louder if needed. They are small for the 12" catagory, very musical and blend amazing well with my KEF IQ7’s. IMO, GREAT subs.
Hm, was looking at OSD stuff. They got budget amps too.
Their 8" looks interesting.
Edit: Just bought the 8" for $180 using code extrasaving10
Those look super interesting, I’m gonna have to do some more research on them, but I’m definitely intrigued.
I ended up ordering a Monoprice Monolith 10. It’s supposed to arrive tomorrow, so I’ll give some impressions once I get some actual listening time in on it
So, how’s it going?
So far I’ve been impressed. It definitely digs way deeper than my old sub did. I haven’t had a chance to watch a solid bass heavy movie with it yet, but I’ve listened to a fair amount of music and played some video games with it and I’d say that it gives a lot of weight and impact to things like explosions and gunshots in games. I ran the Edge of Tomorrow opening and was able to get all the stuff on my walls rattling lol.
It’s built like a tank too. It’s a 10" woofer, but the thing weighs like 70 pounds. I think in Zeos’ review of the 15" model he said something about the front grill being built like it was meant to be a coffee table and I’d say that’s true of the 10" version as well lol.
Feature wise it’s very simple. You’ve got line in, xlr in, and there’s an xlr out, I believe so you can daisy chains subs if you buy multiple. It also has auto on/off, which like, every sub does these days, and two EQ modes, THX and Extended. My understanding is that THX reduces overall output a bit in exchange for less distortion, and Extended just keeps the maximum output available.
I think the thing that’s probably the nicest feature (based on my analytical understanding of it) is that it has a phase knob instead of just a switch, so you can sweep it from 0 to 180 degrees, rather than just having either 0 or 180. I’m not knowledgeable of how to best set up phase angle, I suppose you’d sit in your primary listening position and listen to something you’re familiar with while you have someone else adjust the phase until it sounds best to you?
