Hello, I’ve been looking at many headsets and I’ve came to the conclusion that no headset has a mic that is as good of quality as the V-Moda boom pro for my budget (under £100).
If anyone could suggest any CLOSED BACK headphone combinations for the boom pro that will work well for Xbox gaming / streaming I would be highly grateful!
Would semi open be an option? Something like the K240 with a mini xlr adapter or the Superlux HD668 with a 3.5mm coupler might work if so, keeping it under $100
I believe the boompro is a 3.5 mm connector and that’s what the pro 82 takes but doing it this was is just a roundabout way to make a cooler master mh751 which has a pretty decent mic
Yeah I think open back would cause (even if quiet) sound feedback back into the mic which would be bad, the cooler master mh 751 look pretty attractive and some people have repeated the Beyerdynamic custom one pro as a good choice too, what do you think? And I was originally attracted to the V-Moda M100 headset but apparently it isn’t good for Xbox gaming.
I have a USB Antlion Audio Modmic on my SHP9500 and do not get feedback loops. I use the setup at work for online conferences and phone calls. I do get complimented on quality. For me I would need to have the volume past comfort levels for feedback.
My issue is I am in cubical land so the noise leaks from my neighbors. lol
Unfortunately, I don’t have a lot of experience with a lot of headphones, but I use my Vmoda boom pro with both my Vmoda Crossfade Wireless headphones and my Audio Technica ATH-M50’s and they both sound great. The Vmodas are a little too bassy sometimes, but fun for games like COD with a lot of explosions. The M50’s are pretty good all around though.
@DriftyWingss I would say the Cooler Master MH751 or MH752, either one is the same just one has a special sound adjuster thing. They are exactly the same headphones as the Takstar Pro 82, just different skins.
Yeah the CM751 seem attractive and if the mic isn’t good enough I can just order a boom pro as use that! Although I prefer white headphones they do have a nice design!
You may want to consider the beyerdynamic mx300. You would probably have to find a used pair to fit your price range…but they are really good gaming headset.
