Are these a big upgrade over the DT1990? (@M0N have you heard both)? I was hopping back and forth between the 1990 and the Neumanns and found a great deal on the t5p
Iām in a situation where:
I basically want the Focal Elex but canāt get them because Iām from Europe ()
thatās why the next best thing seems to be the 1990
however ideally Iād need headphones that donāt leak sound too much (=closed)
so⦠Neumann?
and now these popped up. Thatās why Iām wondering where these fit. Not into V-shaped reallyā¦
Have you looked into the Sundaraās? Not a closed back, but a nice headphone. I have both and if I couldnāt get or afford the Elex, the Sundaraās would be a pretty nice consolation prize.
Sundara is indeed great but it isnāt the best choice because of this need right here
Imo more of a sidegrade tbh. Itās a different sound but not a substantial upgrade
Itās a bit warmer for a beyer signature, but still can get up there in treble. Great imaging and soundstage for a closed imo. Itās nice but does have some signature issues depending on what amp you use
Have you considered a focal elegia? You can typically find them around the 600 USD mark in the us. Thatās the closest thing to a closed elex lol. It is more neutral though and a tad less dynamic
Also just going to guess you canāt find a used or b stock/open box aeon 2 closed?
So the 1990 is going to be more impressive spatially than the nhd20, and also imo a bit more neutral too. The nhd20 is a bit warmer and more relaxed, whereas the 1990 with analytical pads are going to be brighter-neutral and more aggressive. The 1990 imo is more detailed, but the nhd20 has a tad more natural timbre and presentation whereas the 1990 can be a bit too forward at times. Build is solid on both, but imo comfort is better on the 1990, but the nhd20 is more portable. Both arenāt extremely amp dependent from my experience
Really solid, neutral, refined, detailed, comfortable, well built, and a great all rounder for a closed back planar
Thanks, this helps - but BOTH ARE TEMPTING ugh
I can get the 1990 for ~$450 and the Neumann for ~$420 here in Croatia so I guess both are good deals right?
Hey guys just hoping by this Topic to ask if these are still relevant headphones in 2020. What other headphones can you compare these to? How are they for the price? I am asking about the gen 2 version.
I found them crisp, clean and clear. Then after a few months I had to EQ them to remove some treble and add some bass. A few months later I just sold them.
When they were EQād perfectly, they were Focal Elexās. A week after I got the Elexās I sold them.
Well I can compare it only to Eikons for closed backs that I have and that would no be fair. I do like how they sound however I bought them without trying and they are a bit small for my ears so become my wifes favorites.
Sound wise I would say are pretty balanced headphones with good base and detial.
What are you after sound wise? And what you have currently?
There are other options for sure I would probably be eying Elegia(adorama sale) or Elex now. Just Elex is no go for EU and I bought them for nice price.
I have a dt 770 (80ohm). Looking to make a decent upgrade. I want something that has smoother highs, a little better mids, good imaging, spacious soundstage. The thing is I also want the nice sub bass of the 770.
I have made a topic as well if you are interested(not sure if I am allowed to link to it).
P.S. Yeah I am from EU so no Elex but focal seems nice⦠Also the earcups on the T5s are small huh?
Would say that probably standard Beyer so if 770 firts you T5p would fit as well.
I dont know about highs as I am not much trebel sensitive or I havenāt yet bought some treble murder headphones except for M50x
I also dont find them having very spacious soundstage comparing to other HP I have.
Also what music you are listen to and what is you budget. Others might be more insightfull as I am still rather noobie but this also can narrow recomendations.
Can anyone tell me what the sound leak is like on the T5p 2nd gen? Iām considering buying them and using them at the office so not bothering my co-workers is a high priority.
It depends on the volume but I would say they do leak quite a bit comparing to lets say eikons. If you like your music louder and your office is quiet I would consider probably other options.
Another question I forgot to ask: has anyone tried both, the DT1770 and the T5p.2? And if so, how do they compare?
Iām mostly interested in which are more comfortable to listen to for extended periods of time.
