Biggest aftermarket pads?
Hello, I’ve been looking to find bigger pads. I have xl ears, the only headphones I have that fit my ears is the SHP 9500. I tried the brainwaves HM5 pads but, they are just slightly to small. They irritate my ears with long use. I’m looking for pads for that fit SHP9500 and Goldplanar GL2000(I’m worried about the new d shape, I get them today apparently, Soo I’ll see). I would prefer angled pads but its not necessary, I’m really just looking for something that just doesn’t touch my ear. My ears measure 2.90x 1.95 inches. The closest thing I found was the Zmf oval pads, but are slightly to small (I have not purchased them yet)
If anyone could help me that would be much appreciated!!
Thanks!
I’ve had similar issues so I hope this will be of some help. First starting at the GL2000 I think there will only be one good candidate which will be a ZMF pad and it can be stretched to fit the GL2000 I’ve seen it done in the GL2000 thread. Id recommend their universal pad perforated. For the SHP 9500 dekoni choice leathers are amazing and their choice velours are great and the comfort of velour/micro suede is incredible. Dekoni pads are my personal favourite. Their memory foam is incredible
dump eit
but seriously want to know guessing ZMF like the one on argons
I wouldn’t recommend the ovals like on Argon just the universals unless OP wants the added room away from the driver
I was looking at zmf pads just didn’t want to keep having to buy if they didn’t for the gl2000. Just seems like the foam is to stiff on the stock pads
Thank you
No worries they definitely fit, dekonis unfortunately I don’t think would
Im also in the huge ears club, the largest aftermaket pads that I know of are:
Brainwavz XL which are all round pads
ZMFs got a lot of room
Dan Clark store has some interesting pads with a lot of room
Pads made for audeze LCD (dekonis for example)
Don’t know if any of those would fit the goldplannar, but they all list their sizes so you can look it up
