Yeah that’s pretty bad. Makes upper registers of female vocals super forward and agressive as well
Thought it was within that range give or take. I don’t understand how some people enjoy that.
After weeks of listening…
Still Sss problem exist
I noticed on foobar2000 it heard
When 9khz and above bands
Elevated … so a trebile problem
And after watching JV review
On hd800 he says its a common
Problem on most headphones .
And other reviewes linked that
To low quality stack “entry level”
So i guess either you accept that
With its flaws or spend some
Hundreds of $ more on decent
Stack … lose lose everybody
After months of suffering
Decided to buy fiio q5s
Since the akm dac chips are
Better with bright headphones
Also bought the sendy audio
Balanced 4.4 mm cable for 90$
And guess what i found ?
The stock cable sucks !!!
After measuring the impedances
Of left right ground channels
It turned out to cause crosstalk
Aka noise in sound …
So yeah
If you buy blon b20 from drop.com
You will end up paying
another 50-100$
Just for cable replacement.
I tend to use my B20s on a schiit HEL. It calms them way down compared to my THX and EL stacks. Also take a look at Hart Audio cables, you don’t have to spend a ton to get great quality.
