So I have both the yeti and the amp dac ifi nano idsd le and unfortunately for the 100 dollars that I gave for the ifi the yeti seems to be way louder like i need to have the ifi 60% to consider it loud and the yeti at 50% is VERY LOUD that i cant even put my headphones on. I have the illusion that the yeti is also better sounding but that might be because I cant get them to the same volume for a comparisson.Also the microphones amp specs are more detailed than the ifi’s which is not ideal to say the least. Is there something I am doing wrong?
Thanks,
Manos
YETI HEADPHONE AMPLIFIER
- Impedance: 16 ohms
- Power Output (RMS): 130 mW
- THD: 0.009%
- Frequency Response: 15 Hz - 22 kHz
- Signal to Noise: 100dB
Ifi nano idsd le
| Formats supported: | PCM 44.1 to 384kHz/16-32bit DSD 2.8, 3.1, 5.6 and 6.2MHz/1bit DXD 352.8, 384kHz/24bit |
| High-Speed Asynchronous USB 2.0 (32bit/384kHz) | |
| Battery: | Lithium-polymer 1000mAh |
| Power(max): | 1.5W |
