The HD58X Jubilee also works well.
I personally chose the HD650 over the HD600 because I prefer more of a smooth treble and the HD600 is just a bit much for me, also I enjoy the bass more over the HD600. One thing I havenāt had a chance to do is, listen on a tube amp. Is the Bottlehead Crack a solid choice or should I try a Darkvoice? Iām just not willing to spend a ton on a tube amp, but I do want one.
Crack is one of two tube amps worth buying under a grand. The other one is not the Dark Voice
Iāve never owned a tube amp, but was thinking of dipping my toe in the water so to speak. I think I would enjoy the Bottlehead Crack kit. It would be a fun project to get in to.
Outstanding! Do it now.
No, I have more learninā to do. I will buy a soldering kit next month. Then some simple, cheap projects off Amazon (build a clock, build a radio, etc.). Then order an amp kit.
Nah nah⦠this was about Jazz at the Pawnshop. Though, Iām seeing this was mentioned back in July and you subsequently have listed to it. So⦠disregard! LOL
