Bright IEM recommendations
I’m looking for something to replace my BL03s, as I’m finding them a bit too warm for my liking. I’d like something similar to this but with a couple more db in the 8-16k area? Ideally under 100, I can do more if it’s wireless, I’d also really appreciate a wireless recommendation.
Thieaudio l3 maybe? I seen it below £100 recently
Tin T2? Blon 03 and T2 are those “starter” IEMs, one darker and one lighter.
You can always throw foam tips on your 03s too; that’ll settle a lot of the low-end for most foams.
