What is a good budget amp with a sub out?
SMSL AD18 or possibly smsl a2
You could always look for a refurbished av receiver and find one for pretty cheap
Edit: or if you wanted a new receiver you could consider the Onkyo TX-8220
If you don’t have a sub and already have an amp, you could always get a sub with speaker level inputs and use whatever amp you want
its for a friend he ot a kanto yu2 as well as a sub 8 both active so i dont know what to do
Why would he need an amp for the yu2 then? I think it even has a sub out. He would just run the sub out of the yu2 to the sub 8
ah i see i ddidnt knw that . I knew i wouldnt need an amp I just didnt know the u2 had a sub out
yeah, I would assume you just need a y subwoofer cable
You guys think this is a good deal? Lookin to upgrade my Loxije wedge amp - want more input options (phono) and a sub out.
Speakers are RP600Ms
I think so yeah. It will definitely have more features
