I’m far from an audiophile, but I’ve fallen into speaker research lately which has lead me to Z Reviews, and then here. Unfortunately, all of the reviews keep leading me to wanting something that is twice the price or unavailable in Canada, so I need some specific advice based on what’s available up here.
I’m looking for a small sub to pair with my brand new Edifier R1700BTs, in a system that will be used for music only. I’m going to be running a pretty unconventional turn table system where it will go turn table -> Standalone Phono Preamp -> Edifier R1700BTs -> Sub Out to Sub (Aux to Split RCA). I’ll be trusting the R1700BTs to do the crossover work.
I had passive speakers and a receiver, but got rid of them due to how I want the equipment laid out in the room. I know it’s not perfect, but it’s the choice I’ve made.
In Zeos video where he recommends how to set up a Subwoofer (using the Edifier T5 which is one that I’m considering), he recommends doing it all differently, but I can’t follow his advice since I won’t have a receiver or any sort of volume control ahead of the speakers in this system.
Anyways, I was completely sold on the Emotiva SE8, but unfortunately with currency exchange and customs etc it’s going to be an almost $500 sub which is too much for me. I emailed them to ask about Canadian distribution or recommendations on how to get it cheaper, and they weren’t helpful at all… So Emotiva is out.
My options now are
Edifier T5 = $180 CAD
Monoprice 8" = $155 CAD
Martin Logan Dynamo 400 = $375 CAD
Polk 8" PSW111 = $350 CAD
Polk 10" PSW10 = $199 CAD
Acoustic Audio PSW10 = $165 CAD
Or should I just comb Craigslist for a cheap $50-100 sub? I’m just hoping to fill in the low end on some rock albums listened to at moderate volumes, so I don’t need anything fancy.
I would love something with the Emotiva footprint (roughly 12"x12"x12"), and the only other sub in my price range that matches that is the PSW111, but it also has some shoddy reviews online…
I basically don’t know enough about subwoofers to decide between the different price points. I know my 12" Monoprice set up with my home theatre in the other room works great for boomy movie stuff, but I’d like something that adds to the R1700BTs musically, and not just shakes the room, but maybe that’s impossible in this price range?
Long term I want Edifier S3000pros and an equal quality Sub, but this is my budget version in the short term.
Any advice? Thanks!
EDIT: After the suggestion below to look for Canadian Made, I’m adding the Fluance DB10 to my list at $270 CAD
