Can a fiio btr3k run the HD58x?
Has someone tried to do that?
The hd58x can run off a cellphone… so uh i think is a yes.
The HD58X can run off a hamster powered amp! So your answer is yes.
would recomend a balanced cable otherwise you’ll nearly max the Btr3K out :wink:
besides that no other problems :smiley:
