You’d be wasting money. If you plug a 3 pole cable into a 4 pole connector, the two grounds connect, just like they would if you were to plug into SE. So, there wouldn’t be any benefit, but there could also be bad things that happen. Someone else knows, I’m sure.
I know people make adapters that allow you to plug 1/4" into a 4-pin XLR amps, never use them. They can really mess up your amplifier or headphones or both.
