Specifically my Mark Levinson No. 26 Preamp, which was manufactured in the 90’s.
Here are the specs:
THD: less than 0.005%
IMD: less than 0.005%
RIAA accuracy: <0.2dB. Maximum output: greater than 13V (balanced)
Output Impedance: 10 Ohms
Recommend Load for Tape Outputs: 10,000 Ohms
Will it damage my headphones if i plug them in through the balanced outputs with two individual XLR 3-Pin -> 3.5mm TRS cables?
The headphones that I would like to use with the No.26:
- Focal Clear
- Hifiman Ananda
- Fostex TR-X00 (PH)
A heartful thanks to anyone who knows anything about this and is willing to help.
