Can the sound of the in ears vary? I do survey.
A curious thing happened to me that can dismantle the chi-fi theory. (and the world this in general). I don’t know the reason.
The story is simple. A few months ago I acquired the Raptgo Hook, I tested it against the Timeless and I came to the conclusions that:
1-The Hook has more in-depth scene.
2-The Hook has more spacious means.
3-The Hook has more subrgave.
4-The resolution is similar.
Two months later I got a Timeless that was given to me by mistake. I tested them with the same dac/amp and use the same cable on both. The perception was different.
1-The subwoofer is similar.
2-The resolution/texture is somewhat higher in Timeless.
3-The scene seems more massive than the Hook.
What happened?
I have already experienced this with other in ears.
I open possibilities:
- That new sounds “better” because it is new. The brain deceives.
- Headphone/in-ear drivers sound different with use.
- It may be due to an error in the first unit test of the Timeless.
- This only happens with chi-fi.
- I don’t know.
0 voters
