This is the official thread for the Cavalli X + SDAC. This thread is for discussion and reviews.
- 2.6wpc
- Daclifier
Reviews…
Reviews…
Picked one of these up on Ebay to power my ZMF Ori’s. Will update on the power output being enough for T50s/mods when it arrives
Good to see an all in one product that’s powerful enough… and doesn’t break the bank.
Since they are somewhat close in price range, thoughts on this vs JDS Element?
This should be all anyone will ever need. Whether I get my unit repaired or returned and buy another I can say this is where I will be stopping my amp/dac search.
Well the amp is going back to the seller. It fixed the high gain issue but developed this horrible static sound in the left channel no matter the input. Took some pics of the inside when I was messing about if that interests anyone LCX+SDAC internals - Album on Imgur
I picked up one open box for $200, hopefully it’s not the same unit lol!
Mine was from an eBay seller called Blinq, hopefully your’s works out better than mine. I found a NOS original Cavalli LC V1 on abay for a great price so I picked that up instead of buying the massdrop one. Sounds exactly the same
