Closed Back Headphone advice, Affordable :D
Hello! I am relatively new to the audio hobby and I was looking around for a pair of Closed Back headphones, to complement my Open Backs that I already have ( cover all the bases, y’know?). My main options were the AKG K361 or the Sony MDR 7506. Both are relatively affordable and I have heard a ton of praise for their sound. I read around and I seem to see the AKG being the less reliable one, with regards to possible construction issues or difficulty achieving a proper seal.
What would u guys go for? Either of these, some other recommendations? Hit me up!
Thanks!
Hello
It what for Budget section would you spend?
Don’t know anything about reliability issues with AKG. They’re build with plastic but usually the quality is good. A friend of mine have the K361 BT for over a year and has zero complain. I had it for some time also and can say I like the sound, and that it is a very comfortable can.
Can’t say anything about the Sony though, never heard it.
I would spend anywhere under 200 bucks I think. Am open to discovering new things. Wouldn’t really throw the money for a pair of Meze 99 Classics though, that is a bit too expensive for me.
Very interesting… I am kinda wanting to buy it. The Sony are being used in proffesional environments, so I think Sony would be more for the “accurate” sound, and AKG for the “fun” sound?
My experience with Sony has always been with more bass, so I kinda doubt about the neutral tonality. But since I haven’t listened to it, can’t say for sure.
The AKG is a little dark, with warmer mids and bass, but not quite the sub-bass. I think is a very safe, relaxed headphone. It does miss some sparkle for the high frequencies I like with big band metals and strings, but it’s not something really bad.
I’ve seen you’re in Romania, so maybe Europe folks like @Deleeh can help you out better with the other options.
Edit: freaking typos.
The cheapest but very solid would be the Emu Purpleheart from Massdrop, which I find above the Dt770 when the Meze is almost too expensive again.
Otherwise it is quite difficult to find something in this price range.
The Meze would certainly also be a good choice and not even wrong.
You could try the meze neo for under 200€ with a more warm sound
The Sony’s are more neutral if I remember correctly but don’t pin me on it
Also heard good things about the sivga sv006
Use the included velour pads (I bought hybrid HiFiMan-like perforated ones off AliExpress after a while because these babies are worth it) and tape up 4 out of 6 holes in the plate around the driver when you change the pads. Maybe also add a single layer of paper towel under the pads if you find the sound too bright. With these simple modifications you can get sound quality that would cost like 2-4x the price. If you also EQ in some more energy at 250 Hz they get damn near reference-grade.
Just don’t expect these to isolate too well. I’m recommending them for pure fidelity/price ratio.
I usually rely on Rtings to dictate the sound signature when I haven’t personally listened to that set of headphones. They say its relatively ok. Another option would also be something like a QC 35 II which i use wired when needed, and wirelessly otherwise, for a dual-use item. I am still very much undecided.
Thanks for the imput!
I have a pair of HD 598s already, and I dont think the Superlux really provide any meaningful difference in quality. They should be more closed than the Senn, but still not quite what I am looking for I think. Very interesting idea though, for someone starting out in the Audiophile hobby and doesn’t wanna spend a fortune
I am a co-coutryman with Meze but I still cannot quite consider the 99 quite in my price range. I was sort of looking for a closed back to see how they go, and have a pair around. I am not sure I wanna jump so high on my first taste into the real Closed back headphones, and I would rather invest the residual cash into something like a Sundara to get some big sound upgrade?
Not sure if closed back headphones really do provide much for the cost, since I don’t quite need the isolation while also having a wire. If I want isolation I go with a wireless ANC pair, and if I want sound, I go Open-back headphone.
