I just want to make sure I’m getting the correct TS to RCA cables to go from the Scarlett Solo rear outputs to the RCA in on the Liquid Spark and I haven’t found anything definitive (probably because it is obvious and I’m missing it). If anyone could recommend a set, it would be greatly appreciated.
Also wanted to say thanks to everyone who knowledgeably comments in this forum. I came here from DMS on youtube and have watched Z-Reviews for some time out of interest in this whole world. I definitely went down the rabbit hole figuring out my upgrade path over the past couple weeks. The information here has been extremely valuable.
Yes, it would be 1/4 inch ts to rca, these are nice. All you would do is max the monitor out on the Scarlett and control volume with the spark, pretty great setup
Most home-studio (and pro gear) with balanced jacks for input or output is fine with talking into TS.
IIRC the 2nd Gen Scarlett interfaces were a bit more picky and would disable output 1/2 if you plugged TS into the balanced outs (could be fixed by unplugging the USB cable/powering the device off and on).
Sorry it has taken me so long to respond. @mazeframe, thank you for the tip. I’ll make sure to try that if I experience any issues on set up. Should have everything on Friday (May 8th).
Been over a month now. Everything works great. I’m really loving the DT880’s paired with the liquid spark. Thank you @M0N and @MazeFrame for the quick replies. Really helped me out.
