New development. Crinacle now has a correction for the bias of his measurement rig. Explanation here. So if we look at one of his raw measurements on his site now:
We still see the raw measurements – in this case BLON B20 in green – but with a grey overlay of a neutral reference target that incorporates the correction factor for his rig.
But brilliantly, you can use this to generate a compensated graph of the same data. Just click on the baseline tag for the IEF neutral target below the graph. The graph now shows how the headphone in question departs from neutral:
(And look just how neutral the B20 is right out to 5k.)
Want to know how the Seny Aiva compares to that? Pin the B20, then add the Aiva:
All they need to do know is add Oratory1990’s headphone measurements to their database to create a truly amazing resource. They’re probably working on it as I write this, grin…
