Hi,
I’m looking for some help and advice for my setup.
My home office currently has a PC setup, Mac setup and Apple TV. I’m running a Topping A50s and D50s as the hub of my system. PC is connected via USB, Mac is connected via COAX (using a Topping D10s). I have power speakers running off my D10s, and a Topping PA3 for my powered speakers. Apple TV connects via bluetooth.
My setup is across a L shaped desk with speakers per setup (my passive are used for mucis, active are mostly used for Teams/Zoom calls and YouTube to be honest).
I want to split into two dedicated setups.
My work/production setups needs DAC/AMP (stack or combo) for my MacBook Pro, Apple TV (and in a incoming Mac mini), that will also have my Mackie powered speakers. I usually use Drop DCA Aeon Open X on this setup.
For my PC, mostly used for gaming, but will be learning video editing and also for listening to music when not working. Because of my zoom layout, this DAC AMP (stack or combo) need to have RCA or XLR out for my Topping PA3 too. I mostly use my DT1990 Pro on this.
I also have DT177X, Focal Elegia, Sundara and Moondrop Kato.
I have been reading up/watching reviews on the DX3 Pro+, DX7 Pro, Asgard 3 (with ESS DAC), Matrix mini 3, Fiio K9 and some others.
I don’t know whether my A50s/D50s stack should stay my daily driver and I get something simple for my PC, or if I use that on my PC with the PA3 and I get a new stack/combo for my work setup.
Any advice would be great. I’d upload a pic but if won’t let me. If anyone is in the DMS Discord I can ping one in there.
Cheers,
Stev e
