giving a $250ish budget for each item, what DACs, Amps or Combo’s would you recommend if you sought the following sound profile:
- Warm Sound
- Neutral Sound
- Detailed / Analytical Sound (Cold Sound, as it were)
as examples, R2R DACs and Tube amps are said to impart warmth to the sound.
Have you taken a look at the Topping D50s and XDuoo TA-10?
M0N
3
For 250, if you wanted a r2r, the only option I could think of would be to try and find a used audio gd r2r 11.
For a neutral sound, the jds labs atom and a topping d10 or higher range dac perhaps
For the warmer sound, the liquid spark and something like a schiit modi 3 or an xduoo ta-10
For something more clinical, perhaps something like a topping dx3 pro
You could also consider the asgard 3 with the dac for 50 bucks more then your budget, but it’s got plenty of power on tap
nope…I put this up as a general purpose question. it would be interesting to have 3 DACs and 3 Amps to mix match and play with for sound.
you can put up any recommendations you want to M0N. I only mentioned R2R and Tube as the general description for sound is on the warm side.
for the clinical, do you have suggestions that aren’t a combo?
