Hello again,
So i have purchased the Denon Ah D7200.
And i can say it make same alarm on the Soundstage.
It is a calm Headphone a little bit fewer in dynamic as the Fostex.
The Fostex say so here i am let‘s play.Denon say you want to play,let‘s play. In short word.
What can say first i know not everyone have 1000$ for free on his side.
But the Buildquality to compare with the Fostex is so better.
Is not so fragil as the Fostex when you put it on/ off.
You don‘t need any Earpads or same else.The Earpads from the Denon is adjust on you ear nothing push or sweat on it.
For Glassviewer is no problem no hurts.
And you don‘t need to Mod him, why the Sound is great.
He have a spectacle Soundstage. When you hearing Livemusic for example.(You American people like it spectacle,
Rock,Hip hop good baserange.
Pop is depend a little bit.Is pop music.
Jazz and Klassik beautiful (Nora Jones for example a dream,or Alicia Kees)
Techno, the Headphone like this.(Armin van burren,Atb ohlala)
The Bass is so good, basshead like them.On point, heavy and depp
Middle are clear and soft,warm.
Highs is depand,the highs are a little bit under.But with a Eq is no problem to adjust them.I find this good so you can choise yourself what do you want.
On the Fostex tr x00 Mahagony i find the hights to high a little bit.
In Soundstage i find it intimate, is great but not so great and not to small.
In comparison with the Fostex Tr x00 i find he play more brillant the Denon.You can hear the harp comes,on the Fostex too but not so beautiful and calm and weak.
One critique point it push a little bit on the Head.The Fostex too.
On the Fostex i have buy the Headband from Beyerdynamics Custom and install on it and at this time never i have problems.
I will tried this on the Denon next Time.
My courently Setup is
Cambridge Audio Dac Magic 100 modified
Schiit Loki and Schiit Vali 2
Tubes
I habe try the Electro Harmonix 6922 Gold Edition.
The Bass i find is too much with them,the Rest are a Good Vocals,Highs.
Tube Electro Harmonix 6c7g Standart
I find it is the Best Tube for the Denon.Why?
The Denon are a little bit under the hights ,with this Tube is directly adjust.The Bass came smooth and clear, and the middle too.
On the Loki all are about 1 o’clock position.
And play on the Low gain switch.i find it better.In the High gain Soundstage comes near on the ear.
For more Information about the Denon my German friend her can say more in Details
