I am thinking of buying some speakers to use on the PC. My budget is up to $ 700, I usually listen to rock, metal, hiphop etc. (a little bit of everything). Up to $ 700 what speakers recommend? If I don’t have an amp / dac, do I need one? I walked the fi5 k5 pro but I don’t know if it’s a good option.
KEF Q150 are still on sale right now for $299, I think that is a pretty good deal and would work well for nearfield. You would still need a speaker amp since they are passive though. you could get a Topping PA3 or step up to something like a Emotiva bas-x 100. You will also need a DAC to send the signal to the amp…
I see that you have a 6xx which is definitely a HP that benefits greatly from a nice amp, If it was me I would take this opportunity to get Fiio K5pro which you can use as a dac for your speaker amp as well as a good headphone amp for your senns.
