Do I need any extra cables
Hi guys, new to using amps and dacs. I got my Sundara, Drop 789, and am still waiting on my Soncoz LAQXD1. I’m going for a balanced setup and I think that means I have to buy aftermarket cables? Are there any that you guys would recommend, and is there anything else that Im missing that I should order while I wait on my DAC
These are the cables I use and finally to be good quality and versatile. The Hart system is very nice because in the future you can just buy the various interconnects as you need to connect to your source without changing the headphone cable itself.
Connecting dac and amp
2 Units - 0.5 Foot - Balanced Microphone Cable Custom Made by WORLDS BEST CABLES - Using Mogami 2549 (Black) Wire and Neutrik NC3MXX & NC3FXX Silver XLR Plugs https://www.amazon.com/dp/B0979K6MTX/ref=cm_sw_r_cp_api_glt_fabc_TBD1BHKNCN167ADVNKJJ
For the sundaras cable
