how are they?
I want something on-ear, light and wireless and these fit that.
I am considering to pair some KPH-30i with a Bt DAC /Amp too, in which case I’m open to suggestions on what you think would match their sound profile.
how are they?
To my knowledge they are excellent. Lightweight and comfortable, with good sound quality.
You can think for pairing with a Bluetooth DAC/Amp, consider the FiiO BTR3K or EarStudio ES100.
Both match the KPH-30i’s sound profile well.
Also you can check this website=https://www.reddit.com/r/gadgets/comments/Uipath Installation/8gx5n5/koss_porta_pro_wireless_review_a_classic_mistake/
I opened the thread thinking why didn’t I know that a wireless version existed to realise that people are adding BT DAC/AMPs
For reference I’m using Qudelix 5K with them.
you came in thinking properly…there is a wireless version of the Porta Pro’s.
The kph30i is a bit bright and slightly less bassy than porta pros. I think a warm sounding bt source would suit it better. It’s a pain to attach the yaxi pads on kph30i.
It is slightly difficult to get the Yaxi pads on it but it definitely benefits a lot from them once installed
Agreed! I like my kph30i more than porta pros.
