DT 770 Pro Replacement Ear Pads?
I’ve had the Beyerdynamic DT 770 Pro 250ohm version for about 3 years now. I want to replace the earpads on them. I use them for gaming, and I tend to go on for long sessions, so comfortability is a must.
I’m not knowledgeable about which ear-pads are compatible, and what the differences are when it comes to the different types of earpad materials, and how they affect the headphone sound.
I’ve seen earpads on Amazon go as much as $60, and I’m not hesitant on purchasing $60 earpads, but it’s got to justify the price tag.
Anyone please advise?
If you wanted to maintain the same signature and comfort the beyer 770v pads are what you are after. If you are looking to change the signature there are lots of options, what sound are you after
I do think the ZMF Eikon Lambskin pads are worth trying, but they are $70.
I’ve tried the Brainwavez pads, not a fan. Stock pads are better imo cause they actually seal around the ear.
I use the headphones for gaming, fun factor, little bit of competitiveness.
Might I suggest these
