hi guys , im searching for a memory foam pads, inner hole of 65x65 (something around that) but the most important thing is the thickness - 25mm
i have brainwavz xl perforated and yes they are good but they are 30 mm and i don’t like the wider sound-stage.
tried to search myself a lot and asked brainwavz if they have anything suits but unfortunately not ![]()
so thanks to everyone who helps , prefer hybrid pads but anything that suit will be nice to try <3
Had my dimensions sheet up as you asked this question. The Dekoni K7XX Pads are inner Dimensions of 63x63 and a thickness of 27mm. Outer dimensions of 106x106. These are a twist lock system though, you would have to take the plastic twist lock ring out and possible tape or glue the pads to your headphone. Let me know if you need pictures of this.
