Earbuds? - within my budget, blues music mainly
Hi guys, Im trying this website as cant find reasonable answears on my thing on youtube neither forums Im already member of I ddcided to try it here and hope for some luck
Soon my birthday and would like some good earbuds for budget up to 200 USD, if we stay lower, better
Depends fe if the earbuds for lets say 60USD would been much worst than those for 120 USD…you got my point
Im not aware if earbuds is a good to listen to jazz, blues if fe headphones or IEM isnt a better pick, but if someone has time You can explain, give me tips or talk about Your own experience
Thank You all! Happy New Year
You should first check if the shells fits you, you can try the Yincrow X6 (MX500 shell) and the Qian39 (unique shell, but my rikubuds gen 3 uses an upgraded one thats similar), Should be less than 30 usd for both.
If they’re still in stock, I got two sets of the Sennheiser Momentum 3 ear buds for $99 each new with warranty. For vocals, acoustic, and blues tracks they’re fantastic. Yincrow X6 is great value for $12 or so, but the Momentum 3 is a big upgrade and wireless convenience.
Thanks, Sennheiser maybe possible, here in Czech only those really good brands and well known are available, do not want to shop on Amazon or ebay, in local stores all the good brands in stock, with the cheaper…no way to get it out of Amazon and I would like to invest into something bit decent already, so will try your advice on Sennheiser, any other suggestions are highly welcomed, but these that you described may be what Im looking for.
Happy New Year to you!
That is not an earbud, its an iem.
Just seen momentum 3 out of stock, momentum 4 out of budget, need to look elsewhrre, but thanks for help, seems like a friendly forum:-)
