@MazeFrame @Bmn1251 Yes. That was actually the first thing I did.
Have you tried swapping L and R in the back? Or tried the outputs as inputs (they are just feed through, so no harm in trying).
Now that I did not try. Just tried it and no bueno. Same issue.
Hmm. If you have not already, time to contact Emotiva.
I did. they are sending me a replacement. Apparently they are in Franklin, TN. Which means, where I live, itāll be here tomorrow. The current amp was like that. Ordered it and woke up to a shipping notficiation. LOL. Oh and their customer support is excellant. Even with this, just a silly issue could happen to any unit, love me some Emotiva.
Oh and thank you all for the suggestions. I really appreciate the help.
Couple of months later, still loving the little amp. Still a bit too noisy with headphones but not as bad as the first unit.
Definitely not an IEM amp lol.
But for speakers, I donāt think you can beat it at this price.
Makes me curious what Emotiva can do with a bigger budget.
looking to buy an a 100 non basx just for speakers, really wondering if there is a notable upgrade from a cheap receiver, even though the receiver has more power (120watts) , it uses a very cheap power board and very cheap low farad filter caps. hopefully its a pretty big upgrade. from 2004 30$ sony receiver lol @blackjakals @M0N @Nick_Mimi
Are you talking about the TA-100 receiver /dac/amp unit? If so i am not familiar with that piece. The bassX A-100 is what i use and continue to enjoy.
At under $250 shipped for a brand new unit i personally find it one of the best values available. Itās not perfect by any means but has solid useful features. As long as the rest of your equipment is of similar price and quality i donāt see an issue. Good luck
I am talking about the A-100 mini X i should have clarified. i believe its the exact same speaker output section. Thanks, just looking for an upgrade to the sound, and i dont think im letting the UB5 shine with my cheap receiver.
On their site and canāt find that particular model. If all it lacks is the HP output it should provide similar sonic performance, which as i stated if using similar quality and price components should perform well
In my opinion, itās a noticeable improvement. I switched from my older 90 W per channel Sony receiver and it immediately sounded better.
Question- cranking the volume knob past about 60% I start to get noticeable hiss- whether itās my Dekoni Blues or my 880 600s. If I remember correctly Zeos makes a point about how you get none of that on the 880s because thatās the amount of resistance there is. Iāve tried feeding it with both my Grace SDAC and iFi Zen and get the same result. Now, my Zen is USB powered, and I can get a iFi Power Supply 50% off plus shipping right now. Will that solve my problem? Is it because Iāve only ever tried using a USB powered DAC or is it simply by nature of the fact that itās a fucking Speaker amp with the jumpers installed and thatās never going away regardless of the DAC quality/power type?
The bias-current hiss should be constant volume.
Just checked on mine and the hiss on mine gets louder only after 3 oāclock.
Maybe try unplugging everything except headphones and power and listen to what should be a near constant volume hiss.
Yeah. It is a speaker amp first, headphone amp second.
Might still want to make sure it is not deffective.
I definitely donāt think itās defective. The same thing happened both DACs going into my SP200 at a certain level of volume, but once I went balanced from the Zen to the SP200 it really took away the background and made it a lot quieter, partly by virtue of the fact I didnāt have to have the volume up on the SP200 as much anymore. Thatās why Iām more convinced itās just the noise RCA from a USB powered DAC
Sounds like a ground loop honestly.
Thoughts on no-jumper vs jumper?
Iāve purchased this amp to hook up a set of speakers in addition to headphones. I primarily listen on my T60rp Argons. If I get all of the volume that I need out of the box, is there any other advantage to installing the jumpers on this?
No, itās my opinion that this āpage 11ā mod really isnāt worth it due to the severe amount of noise it puts to headphones. Have a look at these two posts of mine from December.
Donāt think of it as noiseā¦Itās more a classic 50ās hi-fi sound signatureā¦
Unlike others who claim hissing at knob levels below what would literally damage your hearing itās a delight and I think i would much rather own the Bas X A-100 + 880 600ohm + 990 600hm that the 1990ās as I listen for fun and enjoyment and have the sundaras as a stopgap between fun and criticalā¦
That being said itās an improvment over my Magni 3 as far as quality goes (I use it soley for my DT990ās) but itās fucking scary to have hooked up for a $350 set of cans since 20% of knob is 100% volume, so I keep my Sundaras and my incoming 6XX on schiit magni 3 and use an Aux switch.
Worth every penny just to drive my DT990 600ohms though and I surely will be getting more hard to drive headphones in the future to experiment and take advantages, as well as maybe some actual audiophile speakers to replace my Z906 system now that I have this amp hanging around.
