Hi,
Before I begin I have to point out that English is not my native language and I am very new to the whole audiophile thing. So please forgive me if I said anything stupid.
Things I currently use for PC:
SHP9500 headset
Asus xonar D2 sound card
a small no brand type-c usb dac from a local DIY seller. It uses ALC 5686 chip.
The D2 is old but the headphone output still quite ok. The sound is clean and better than mainboard sound chip. That type-c usb dac was originally for my cellphone. It’s just about 20 USD or less. I tested it with PC and found it’s quite good with SHP9500. The sound is louder and more vivid or exciting than D2.(sorry, don’t know how to use the right word to describe).
The problem is it’s not very stable. Although there’s no background noise if I didn’t play anything. But sometimes there’s some hiss or delay when I change the song or doing something else with other program. It’s not always, but noticeable when it happens. On the other hand, the xonar D2 doesn’t have this issue.
So I am thinking maybe I should get a DAC/AMP combo and just use D2 as S/PDIF output source. Right now I am thinking some possible choices.
FX-Audio DAC X6 or the new MKII model
SMSL M3
I know any of the above will sound better than the onboard chip. But will it be better than xonar D2’s analog output?
According to asus, D2 uses Burr-Brown PCM1796 *4 as D-A converter. DAC-X6 uses CS4398. The DAC-X6 MKII uses ES9018K2M. the SMSL M3 also uses CS4398.
I know it’s not fair to just use these spec to compare. But can I get a general idea about how much improvement I will get if I add an entry level DAC to my system? Should I worry about hiss or background noise in DAC of this price range?
And if it’s not much improvement, what DAC/AMP combo should I get? You can tell my budget is kind small by the choices I list above. So maybe under 100 USD? What else should I consider?
Thank you for reading my question. Any suggestion will be appreciated.
