EPZ 550 The new reference set
Specification
Cavity Material: Aluminum Alloy
Drivers: Sonion 38AM007 + 26A005 + E50DT
Frequency Response: 20Hz - 20kHz
Sensitivity: 105dB (±0.5dB)
Impedance: 14Ω
Plug Type: 14Ω
Connector Type: 0.78mm 2-pin
Cable: Monocrystalline Copper Plated with Silver
Cable Length: 1.2m
5BA configuration, tuned for a clean and natural presentation
Bass
Dual Sonion 38A for bass
  • Natural, slightly relaxed low end with good dynamics
  • More “DD-like” feel instead of typical BA stiffness
  • Solid extension with good texture
Mids
Dual Sonion 26A for mids
  • Clear, transparent, slightly sweet vocals
  • Good detail in vocal nuances (breath, positioning)
  • Clean imaging and natural presentation
Treble
Knowles high-frequency driver
  • Clean and smooth treble with strong detail retrieval
  • Good extension without harshness
  • Adds clarity and air to the overall sound
Cleaner, More Coherent Sound with Knowles Dampers
Enhanced with Knowles acoustic dampers, the 3-way crossover achieves higher precision and cleaner frequency control. Each band is finely tuned to reduce unwanted artifacts and ensure smooth, interference-free transitions between lows, mids, and highs. The result is a highly coherent sound with strong clarity and resolution, while maintaining BA speed without sounding sharp or unnatural.
Sound Signature & Curve: TBC
New Rear Venting System for improved bass and staging
In multi-driver IEMs, rear chamber airflow plays a key role in bass texture, soundstage, and overall clarity. With this in mind, EPZ developed a new rear venting system for the 550, optimizing airflow to reduce unwanted resonance and improve acoustic control. This results in deeper, more natural bass, a wider and more open soundstage, and a cleaner overall presentation, while also improving pressure balance for more comfortable long listening sessions.
Full metal shell, precision CNC- machined
The shell is milled from a solid metal block using high-precision CNC machining, offering excellent structural rigidity. Compared to typical resin shells, this helps minimize unwanted resonance and contributes to a cleaner background with better overall clarity.
Ultra-compact shell design, Maximum space utilization
Despite housing a 5-driver configuration, the internal structure has been carefully optimized to maximize space efficiency and keep the shell compact. This results in a comfortable, ergonomic fit with minimal pressure, making it suitable for extended listening sessions.
High-purity 4-core 6N OCC silver-plated copper cable
High-purity 6N single-crystal copper ensures low-loss signal transmission, while silver plating enhances treble extension and overall resolution. The stock cable further unlocks the 550’s naturally clean tuning, delivering tighter, more solid bass and improved vocal transparency in the mids.
6 Pairs of Ear Tips Included
M100 liquid silicone tips:
Designed for better sealing and cleaner sound, reducing low-frequency resonance and smoothing out high-frequency harshness. Improved isolation helps prevent bass leakage, resulting in a tighter, more defined presentation with clearer layering and enhanced wearing comfort compared to standard tips.
ATO7 silicone tips:
Tuned for a more engaging sound signature, adding low-frequency body and atmosphere while extending treble performance. The soft material also ensures a comfortable, secure fit for long listening sessions.
Design Philosophy
Inspired by the image of feathers drifting from a bird in flight and the phoenix moving through vast forests, the EPZ 550 is shaped around the idea of harmony between nature and aesthetics. This pursuit of “natural purity” is reflected not only in its visual design, but also in its acoustic tuning, aiming for a clean, balanced, and transparent sound with minimal coloration.
For years, EPZ has focused on resin-shell earphones that offer a warm and comfortable wearing experience. With the EPZ 550, the brand takes a new step forward with its first full-metal design, exploring higher structural rigidity and a more refined acoustic foundation for a more mature listening experience.
The EPZ 550 is a reflection of both natural inspiration and our continued pursuit of pure sound. It is designed to accompany you through everyday noise, delivering a clean and immersive listening experience where music feels honest, calm, and uncolored.
Here is a link to my review for those interested. https://youtu.be/cMSieWMB4OM
Holy shit those are gorgeous
