Equalizer apo (with peace) Just WILL NOT WORK
Specs:
win10, MSI b550 gaming plus, earthquake iq52b’s
I for the life of me can’t get this god damn program to work, there is 0 change when clicking the on/off button to put the changes into effect. I have no idea why. I don’t even have the msi realtek drivers installed! It’s just windows stock! I’m even using the 3.5mm out on the back of the mobo. I am hopeless right now, I am not good with software. It’s been 3 hours and I’ve gotten nowhere.
When I change the volume level (not the pre amp gain) it does change the volume, so the application registers a form of change, but every other thing doesn’t work.
do I need to restart my pc after clicking the on/off button into the on position?
Under the settings, I have “Show warning if equalizer apo isn’t installed on the selected device” checked, and I have never gotten a warning, so I feel confident in believing it is installed correctly.
It registers that I have the configuration selected, as the tray icon changes to the custom color i set for the config (red instead of blue).
custom configs nor default configs work.
I have tried music on youtube and music saved to my hard drive.
I have “enable audio enhancements” under my speakers turned on in win10 sound settings.
You are not the only one.
Some have found a fix with in these topics.
https://www.google.com/search?q=Show+warning+if+equalizer+apo+isn’t+installed+on+the+selected+device&oq=Show+warning+if+equalizer+apo+isn’t+installed+on+the+selected+device&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
