ES100 EQ settings Megathread
Hey everyone, just thinking this may be good for others to add to etc. These are some as settings I’ve used with it and the corresponding IEM.
Isine 10
Trn X6-more of a dirty eq that really balanced them out and still kept the detail imo.
Tin T2 EQ. Sounds great with this. Using the wide (.7071) Q factor.
My ES100 equalizer setting for my Nissan 370Z factory Bose system running through the console AUX inputs.
Anyone’s ES100 stop working?
Mine started to turn off when I would pause audio without the little power down jingle. I didn’t think much of it cuz it didn’t really bother me, but then about a week later (yesterday) the audio started jittering and stuttering as if I was going out of range even though I keep my phone in my back pocket and the ES100 in my front pocket. It got to the point where i had my phone and the amp in the same pocket and every slight movement made it garbled. I tried resetting my phone and the amp several times and then in a last ditch attempt I tried to forget and pair the amp anew and now my phone won’t connect to it.
Has this happened to anyone here?
Are you using it with the LDAC codec set to max. bitrate by any chance? That would make it highly sensitive to ambient RF noise, to the point that it might stutter even with the Tx and Rx devices being literally stuck to eachother.
Even if I was it doesn’t explain why it won’t connect to my phone anymore. The stuttering was more like black outs before I lost the ability to connect to it
So here is one a came up with for the OH10:
This is one for someone looking for a fuller sound and more forward vocals. I dont prefer it by default but is still good and for those looking to make the OH10 a bit more neutral without messing with the treble.
It makes it sound more like a hd650 with vocals but still getting a great sense of the room. It loses the magic of the IEM imo. Maybe this will help someone.
