Hey guys, currently I’m building my audio setup. At first as headphone AMP i wanted to order Topping A50 but it isn’t available in Poland and also I do not really want to wait few weeks so I started to looking and I’ve found AUNE X7S which looks very promising. I know it’s kinda different price range but if it would be worth I can stretch a little bit.
Headphones I’ll use: DT 1990 pro
DAC: most probably Topping D50s
Hmmm, well if I had to pick between the two, I would go a50, as imo it performs better single ended than the aune, and with the 1990 being only single ended, you can’t really take advantage of the x7s
So I would say that they might be a bit similar with the 1990, my preference tends to lean towards the 3+, but that being said if you are going for a d50s, the a50 would be a nice matching stack
