Everything SJY Audio
I did a pretty intense re-cable project on the speaker side of the desktop/near field system today, and while I had everything apart, I couldn’t help myself. I reconfigured and tried the Horizon Closed on the AMP-F2 / SA-1 pre setup. And I’ll be damned, it was better. The stage was bigger, imaging /separation was improved, mids right up through the highs were spectacular. It’s a measure more neutral than the DA-9, and the bass isn’t as authoritative as the DA-9. Bass hits harder and extends lower. Oddly, I also have more headroom on the DA-9. And I have volume control right there at the amp, so no preamp is required.
At the end of the day I ended up putting everything back the way it was. The AMP-F2 will continue to be a dedicated speaker amp. But I’m glad I did it. It’s yet another great option for the Horizon Closed that I can switch over to pretty easily whenever I get the itch.
more glazing reviews
My thoughts on pairing my SJY Audio headphones with the Valhalla 3. :wink:
A little update, after 1 hour + of listening Starry Night V1 seems to have tripped the protection circuit in the Valhalla 3. :sweat_smile:
Horizon is not having an issue as of yet, so I guess Starry Night V1 (first run) continues to be power hungry. :crazy_face:
Edit: *It happened again with another headphone, I think it might be running a little too hot, I just repositioned the amp, and I will report back.
Update: I reseated the tubes and so far so good with the Horizon Open.
Switching back and forth from Horizon Open to Verum One Mk2 has made me appreciate the Verums even more, for 350 dollars they sound spectacular and close to Horizon Open maybe with tad less detail, but dynamics/soundstage are almost on par. [to my ears at least]
Horizon Open - Gold drivers
Horizon Open - Aluminum drivers
Anyone waiting for their horizon carbon closed from apos?
I am about 2 weeks now.
According to apos, there were large influx of orders recently and Jeff been working hard to get the orders done.
It seems to have gotten a lot of traction in the wider audio community, and I would assume there is quite the number of backorders. I have not ordered one myself as of yet, but I am sure that he is working on getting them out as soon as possible.
I will continue enjoying my Horizon Open on my Valhalla 3 until then.
Hopefully you will get your Horizon Closed Carbon sooner than later. I am sure that they are worth the wait. :wink:
Welcome to Hifi Guides!
his own website has 2-3 week fulfillment times as well
Thanks for your patience. There’s been a big wave of orders, but I’m working through them as fast as I can. Really appreciate the support.
@MindBreak looks like a portable tube that might be respectable to drive horizon is coming from Cayin.
That will be interesting, but unfortunately waisted on me since I don’t take my Hifi on the go. Options are always nice, and I am sure there are those who are ready and waiting to place their order. :wink:
Aside: If anyone can pull that off it would be Cayin. :laughing:
I’m going to take a jump and probably pair it with my C9ii lol, tubes on tubes!!!
The Tube Addiction is strong in this one. :crazy_face:
I have received the headphone and have to say its worth the wait and sounded amazing!
Its very detailed, clean, open and works well with all genres of music I throw at, whether its vocal midrange or instrumental layerings. The bass response is fantastic and didnt bleed into the mid, it does need quite a bit of power to drive it, but otherwise its really fantastic sounding headphone.
I would say its very effortless and natural sounding headphone that balanced well through all FR. I have other high end headphones to compare, and it compete and better than a lots of the higher price ones. Only small thing is the adjustment rod is a bit loose and had to adjust every time, but otherwise very comfortable to wear.
Amazing work Jeff! Highly Recommended.
I assume that if you have a small enough allen key you can tighten the rods a bit, at least on the horizon open I was able to
Thanks! Perfect, it works, if I use the small (1.5) allen key to tighten a bit, had to fine tune a bit, it does stop slipping around the rod now.
Better late than never… picked up the SJY Horizon. I kept hearing about how hard they were to drive but I thought my A70/D70 pro could obviously power them but he’s made these cans much more efficient now. Hell even my Ibasso DX 260 MK2 powered them just fine… The music that comes out of this is so rich and detailed that I was left stunned. Now I love my Focal Clear(OG) and Arya Stealth but they cannot pull out all the crazy microdetails this can. The bass was textured and thumpy while the mids are the star of the show. The highs have some sparkle but not ear bleeding high :D. Money well spent… and how many times can you say that about buying headphones?
assuming you bought new so you got the aluminum driver which is supposed to be quite a bit easier to drive but honestly even the gold can be driven off of decently powerful dongles.
